z-ya Posted March 12, 2004 Share Posted March 12, 2004 Ross must be out of town, so I'm posting this questions because it's the only problem still keeping my car on jack stands. I bought the 240SX rear disc brake line kit from Ross, and there appears to be a problem. On the passenger side, where you remove the short piece of hard line from the "T", and screw in an adapter for the SS line is leaking. Not leaking bad, but any leak in the brake system is not too good. Anyway, after looking at it further, it appears that the end that screws into the "T" is the wrong gender. The hard line I removed is an inverted flare (as are most of the hard lines on old Zs), where the adapeter fitting is a non inverted flare on both ends. This is OK for the end that the SS line screws into, but not so great for the end that screws into the "T". Maybe the wrong adapter ended up in the kit? I know a bunch of you have done the conversion, so has anyone seen this problem before? If so, got the part number for the correct adapter? Thanks, Pete Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted March 15, 2004 Share Posted March 15, 2004 Ross must be out of town' date=' so I'm posting this questions because it's the only problem still keeping my car on jack stands.Thanks, ... Pete[/quote'] Pete, I was out for a few days, you've got mail Quote Link to comment Share on other sites More sharing options...
