turbo charge?
Guest 73-240z
Guest 73-240z
:twisted: I want to turbo charge my 2.4l carb. engine. The only thing I need to know is how to do it. I know I need to loose the carbs, a diffrent exhaust and a new intake manifold. Is there anyone who can help me to find all the thing I need to do this? I dont really even know where to start.
Perhaps a 280zx?
Good place to start is to do a search in turbo forum and also on Zcar.com.Check out this site it has great info http://www.hammondsplains.com/zclub/techtips/
Your L24 isn't a good start to turbo swap due to high CR,around 9.0,plus E31/88 heads which came with L24 engine don't accept FI ( if i wrong on this one someone please correct me ) So what usually people do is to locate used L28et and use it, or use P90 head to decrease CR.
Anyway, do a search you will find tonns of info from engine questions to what rear end you should use.Check also http://www.Zhome.com.Good luck :D
