Guest Zachb55 Posted March 17, 2004 Share Posted March 17, 2004 My turn signals had been working a while back, and now they wont even "click". my hazards work well but my signals wont even budge. the switch works to turn the highbeams on and such, but nothing else. what do you think? faulty mechanism or flasher relay? if its the relay where is that located? -Zach Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted March 17, 2004 Share Posted March 17, 2004 This happened to me once. One side clicked- other not. Hazards worked OK. The problem was the corrosion in the connectors made a bad connection. find the right connector and clean the connection, then it should work. The hazard lights are on a different circuit than the T.S. Hope this helps... The flasher units are aluminum cand located under the dash, but above the steering column ( on 280Z) Quote Link to comment Share on other sites More sharing options...
Guest Zachb55 Posted March 18, 2004 Share Posted March 18, 2004 ok, thanks ill give it a whirl Quote Link to comment Share on other sites More sharing options...
