Guest cool78Z Posted March 27, 2004 Share Posted March 27, 2004 Can I install new steering rack bushings with the car up on ramps or do I have to jack up the car to remove the weight off the suspension? 78 280Z Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted March 27, 2004 Share Posted March 27, 2004 You should be able to do it with the car on the ground! Just remove the bold for the clamps & takethe tops off, then swap the bushings, reassemble and torque. I suppose you might need some leverage to get at the bushings or maybe even disconnect the tie-rod ends, but it shouldn't be too hard. Jusyt time-consuming. I did the sway bar on the ground no prob. Plenty of ground clearance. Quote Link to comment Share on other sites More sharing options...
