Guest BillV Posted April 4, 2004 Share Posted April 4, 2004 Are L69 heads any different from standard 305 heads, I think the compression is higher on the L69. Do the heads have smaller chambers, or are the pistons different. Is the cam different also? I know the L69 is about 30 hp stronger. I had a 84 Z28 with the L69, and it ran pretty good. I think this would be a good starter motor for my ZX until I build the 350 that I want. Also, what about Vortec heads on a 350? (I could use them on a 350 later) Thanks, Bill Quote Link to comment Share on other sites More sharing options...
Guest 77vegasz Posted April 5, 2004 Share Posted April 5, 2004 Go to http://www.mortec.com and look up the casting numbers of the heads you want to know about. Most listings give chamber cc and valve sizes. You can use vortec heads on a 350, go to http://www.jegs.com or http://www.summitracing.com and look them up. They are very afordable, and give excelent performance. Jon Quote Link to comment Share on other sites More sharing options...
Guest BillV Posted April 5, 2004 Share Posted April 5, 2004 Sorry, I meant Vortec heads on a 305 I don't have the casting #, just thought somebody might know. Quote Link to comment Share on other sites More sharing options...
Guest 77vegasz Posted April 5, 2004 Share Posted April 5, 2004 http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=4242&prmenbr=361 Go to this page for a description of applications for the cast iron Vortec heads. It states can be used on all small blocks from 1955 to present. Jon Quote Link to comment Share on other sites More sharing options...
