Guest TJ240z Posted April 13, 2004 Share Posted April 13, 2004 My Datsun 240z is currently undergoing a complete Back Half job, tubs, solid rear, coilovers, 4 link, 10pt etc, etc, so i was wondering what the best option were for a front suspension, brakes, and stearing set up is? any info would help alot thanks Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted April 13, 2004 Share Posted April 13, 2004 The stock front suspension is pretty light, check out this site: http://www.ratsun.com/ Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted April 14, 2004 Share Posted April 14, 2004 He's right, the Datsun stuff is fairly light. I'd concentrate on lightening the brakes, while at the same time equiping them for better stopping. You can change to 5 lug using 300ZX('84-89turbo and '87-89 NA) front hubs. You can get 300zx cross drilled rotors. Use Wilwood or similar 4 piston Dynalight calipers to save some unsprung weight. Don't use the popular Toyota 4 piston calipers, they weigh way too much. Swap in some coilovers, and you'll have a sweet adjustable ride height also. You can use Tokico Illuminas(struts) that are adjustable. You can set them loose for a quick launch. Of course lose the sway bar. I've been threatening to tub-out one of mine. A member here, I think his name is JapTin, has a wicked drag z that is SLAMMED. It looks sick! Quote Link to comment Share on other sites More sharing options...
jap tin Posted April 24, 2004 Share Posted April 24, 2004 The stock front suspension will work fine with your backhalf job. On my old backhalfed car I used the stock front suspension, steering, brakes ect. I put a home made strut brace across the front struts and that was it. Quote Link to comment Share on other sites More sharing options...
