DEFINITION OF ACCELERATION
SpeedRacer
One of my Chrysler buddies sent this to me and I thought some of you might find it interesting.
" DEFINITION OF ACCELERATION "
One Top Fuel dragster 500 cubic inch Hemi engine makes more
horsepower than the first 4 rows of stock cars at the Daytona
500.
Under full throttle, a dragster engine consumes 1-1/2 gallons
of nitro methane per second; a fully loaded 747 consumes jet
fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to
drive the dragster's supercharger.
With 3,000 CFM of air being rammed in by the supercharger on
overdrive, the fuel mixture is compressed into a near-solid
form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric (stoichiometry: methodology and
technology by which quantities of reactants and products in
chemical reactions are determined)
1.7:1 air/fuel mixture for nitro methane, the flame front
temperature measures 7,050 deg F.
Nitro methane burns yellow. The spectacular white flame seen
above the stacks at night is raw burning hydrogen,
dissociated from atmospheric water vapor by the searing
exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the
output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during a pass.
After halfway, the engine is dieseling from compression, plus
the glow of exhaust valves at 1,400 degrees F. The engine
can only be shut down by cutting the fuel
flow.
If spark momentarily fails early in the run, unburned nitro
builds up in the affected cylinders and then explodes with
sufficient force to blow cylinder heads off the block in
pieces or split the block in half.
In order to exceed 300 mph in 4.5 seconds, dragsters must
accelerate an average of over 4G's. In order to reach 200 mph
(well before half-track), > the launch acceleration
approaches 8G's.
Dragsters reach over 300 miles per hour before you have
completed reading this sentence.
Top Fuel engines turn approximately 540 revolutions from
light to light! Including the burnout, the engine must only
survive 900 revolutions under load.
The redline is actually quite high at 9,500 rpm.
Assuming all the equipment is paid off, the crew worked for
free, and for once NOTHING BLOWS UP, each run costs an
estimated $1,000.00 per second.
The current Top Fuel dragster elapsed time record is 4.441
seconds for the quarter mile (10/05/03, Tony Schumacher). The
top speed record is 333.00 mph. (533 km/h) as measured over
the last 66' of the run (09/28/03 Doug
Kalitta).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter "twin-
turbo" powered Corvette Z06. Over a mile up the road, a Top
Fuel dragster is staged and ready to launch down a quarter
mile strip as you pass. You have the advantage of a flying
start. You run the 'Vette hard up through the gears
and blast across the starting line and past the dragster at
an honest 200 mph. The 'tree' goes green for both of you at
that moment.
The dragster launches and starts after you. You keep your
foot down hard, but you hear an incredibly brutal whine that
sears your eardrums and within 3 seconds, the dragster
catches and passes you. He beats you to the finish
line, a quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had
spotted you 200 mph and not only caught, but nearly blasted
you off the road when he passed you within a mere 1,320 foot
long race course.
..and that my friends, is ACCELERATION !
