speed mater cable gear
Guest mykazuo
Guest mykazuo
I have problem speed mater I have 25 tooth gear but fail so I go to parts shop get 22 tooth gear(most highnumber they have) and mater show dable like 20ml cowe out 40ml where i can get 27 or 28 tooth gear
Guest greimann
I'm guessing that english is not your first language, so let me see if we can translate and help out.
Originally posted by mykazuo:
I have a problem with my speedometer. I have a 25 tooth gear but it has failed. I went to the parts shop but all I got was a 22 tooth gear (The highest number they have) and now the speedometer shows double. 20mph comes out 40mph. Where can I get a 27 or 28 tooth gear?
I think you will need to change the drive gear as well as the driven gear to get the correct ratio. This will require removing the tailshaft housing of the transmission. These parts are available at the dealer. This web site will help you determine which pair you will need.
http://www.tciauto.com/tech_info/speedo_gears.htm
Guest mykazuo
Hi Mr Greimann thank you very much collect my english
I saw web site and find out my drive gear is red(7) driven gear grey(22) this mean my tranny mismatch
TH300 and TH400 I thought my tranny is Th300 but drive gear red(7) is TH400
