Timing problem....I think
Guest stilesops4
Guest stilesops4
I put in a new radiator in my '77 280z (because the old one had a large hole all the way through it) and now I believe the timing is screwed up - I have now checked just about every connection that we could have possibly messed with (vacuum lines, distributor wires...) and everything there seems to be connected just fine. The exhaust stutters, the engine shakes (a lot), between about 500 and 1000 rpms the smoke coming out the exhaust is gray, up to 2000 (which is the highest I could rev it before it cuts out all together) there is a lot of black smoke. I think that's all the symptoms. I am going to check the timing later today and if that doesn't fix it....Anyway - any help would be GREATLY appreciated
