Guest 3154tm Posted May 10, 2004 Share Posted May 10, 2004 i'm using what i think is an R200 diff from a '91 infinity q45. the outside diameter of the pinnion flange is about 4 11/16"diameter. this is causing some clearance problems. is there another R200 pinnion flange with a smaller diameter that would be a direct swap? i haven't built my driveshaft yet so hopefully i can find a yoke to match. thanks. frank Quote Link to comment Share on other sites More sharing options...
Guest Aaron Posted May 11, 2004 Share Posted May 11, 2004 The rear of a 91 Q should be a R230. Quote Link to comment Share on other sites More sharing options...
Guest 3154tm Posted May 11, 2004 Share Posted May 11, 2004 aaron, that's what i thought until i read this post. http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=33834 i'm so confused. frank Quote Link to comment Share on other sites More sharing options...
zxgts-4 Posted May 12, 2004 Share Posted May 12, 2004 Hi Frank If it is R200 you should be able to use the pinion flange off another late R200 model. My Z31 flange and S13 flanges both had the same spline and are about 4in dia. I was going to use the Z31 because I can get driveshaft, to modify, easier and cheaper. Neil Quote Link to comment Share on other sites More sharing options...
Guest 3154tm Posted May 14, 2004 Share Posted May 14, 2004 hi neil, what's an s13 frank Quote Link to comment Share on other sites More sharing options...
zxgts-4 Posted May 15, 2004 Share Posted May 15, 2004 In US sold as 240SX. Neil Quote Link to comment Share on other sites More sharing options...
