Thaniel Posted May 11, 2004 Share Posted May 11, 2004 I am in need of a slip yoke that will fit a 350z 6 speed manual trans so I can have a custom drive shaft fabricated. I can not locate any info on what replacement part# (rockford, neapco, spicer) I might use. I was wondering if it would be the same as a 300z. However, I can not locate information for the 300z slip yoke either. From my crude measuring the output shaft of the 350z is 32 spline aprox 34mm dia and around 126mm long. ID of the trans seal is around 44mm. Do these dims match a 300z or any other? Any other suggestions? Help anyone?? Quote Link to comment Share on other sites More sharing options...
Thaniel Posted May 13, 2004 Author Share Posted May 13, 2004 Does any body have a 300z trans yoke they could measure for me?? Quote Link to comment Share on other sites More sharing options...
zxgts-4 Posted May 14, 2004 Share Posted May 14, 2004 Your out in new territory here. 300ZX parts info doesn't list the yoke seperately. http://www.300zx.lv/catalog/?gr=f&sec370 Propeller shaft assy 05/94- MT 37000-30P10 alternate part -VP010 You may be able to measure or try a 300ZXTT yoke at front half cut importer or salvage yard. If 300zx prop shaft comes as an assy the 350Z will probably be the same. Good luck. Neil Quote Link to comment Share on other sites More sharing options...
Thaniel Posted May 27, 2004 Author Share Posted May 27, 2004 Here is some info if anyone else is interested. The 350z trans output shaft is a 32 spline and is not common to any of the older nissan vehicles. The 350z has a "composite and plastic" drive shaft. The G35 has a steel drive shaft. The G35 sedan has a 2 piece driveshaft. I bought a G35 sedan (6 speed manual) trans from a salvage yard. The u-joints are pressed in. No real surprize. The joints however appear to be worn already. Couldn't be more than a year or 2 old. I don't get it. I have also been told the 2004 nissan Titan has the same slip yoke but with removable u-joints. According to my favorite nissan dealer the driveshaft is only sold as an assembly. I haven't found any in a salvage yard so I can't verify that it fits. Basically anyone wanting to use a 350z trans in a swap I suggest figuring out what you are going to do on the driveshaft FIRST. It seems to be a problem. At least until more parts are available. I'm sending what I have to a custom drive shaft shop to see what they can make out of what I have. I've got my fingers crossed. Quote Link to comment Share on other sites More sharing options...
zxgts-4 Posted May 28, 2004 Share Posted May 28, 2004 Hi Thaniel Glad to see that you have made some progress. R34 Skyline uses a 6 speed Getrag but it probably has a Hi tech type driveshaft also! S15 Silvias also use a 6 speed probably closely related to the 350Z. Keep us posted Neil Quote Link to comment Share on other sites More sharing options...
Trevor Posted May 28, 2004 Share Posted May 28, 2004 I just happened to also be looking for a yoke for my oddball GM 5 speed trans. Its a 32 spline, 1.364" (34.6 mm) diam. (actual, common reference is 1 3/8") output shaft. The yoke you seek might be fairly easy to find if my info is correct. Look at the yokes for GM's TH-400, Muncie M-22 (Rock Crusher) 4-speed, and B&W (Super) T-10 4-speed, Lenco, Liberty, Jerico, G Force (Racing) 4 speed. Note a trend here? Heavy Duty Stuff. For a 1310 U-joint you'll want to look at Camaro / Firebird parts sources, unless you find a way of fitting 1330 U-joints at both ends. Found it here: http://store.trackerdesigns.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Driveline $200 for a "racing" part 1350 , but stock parts $5 - $20 at the JY or eBAY. $50 new from Denny's: http://www.dennysdriveshaft.com/html/slip_yokes.html Quote Link to comment Share on other sites More sharing options...
Thaniel Posted July 2, 2004 Author Share Posted July 2, 2004 FYI the drive shaft from made from the G35 driveshaft works. Now all I lack is finishing up. I have put about 10 miles on the car right now. I really need to finish the exhaust before driving much more. Thaniel Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted July 2, 2004 Share Posted July 2, 2004 Sounds like a cool project, keep up the good work. Quote Link to comment Share on other sites More sharing options...
