tail shaft hitting sway bar
Guest quadcamZ
Guest quadcamZ
It is stock up that end and nothing looks bent or broke ie diff mounts and sway bar mounts.
what do you sugest?
i have new diff rubber mounts front and mostache bar mounts on order will this fix it or will have to space the diff up?
got it running and this dam horrid noise turned up. really need help on this one.
  • 3 weeks later...
Guest 350zgto
If you have a V-8 converted car with a V-8 size (3.00", 3.50") driveshaft, are we talking about the driveshaft? (tailshaft?) and if you have a stock type floor mounted rear bar like in a 280Z, I have read the larger diameter drive shaft can make contact with the bar.
