Body Ground
I am trying to figure out where the body gets grounded on the 280z. It goes from -ve post to the engine block. Can't really see where the body is grounded ?? I am looking to redo the main charging system, having some electrical gremlins.
It look like the +ve goes from post to starter, then from there to fusible link, then to fuse box and voltage regulator and alternator.
Usually the wiring diagram are good from the manual, but the charging system it doesn't tell where the phisically hook up.
Guest Aaron
You should have a braided cable (or some large cable) going from the engine/trans to the chassis. If I remember correctly, on my 81ZXT it was connected at the bellhousing on the passenger's side. Bad ground will definately cause you some electrical problems.
