Guest Gillez260ZT Posted May 19, 2004 Share Posted May 19, 2004 Hi, I will soon be installing a TEC2 in my turbocharged 260Z and would like to know if those on this site running TEC2's made their brackets for the crank sensor or purchased them from a third party. Same for the installation of the trigger wheel on the harmonic balancer. I know Top End will do it all if I send them my harmonic balancer but I wonder if there are any other sources. Thanks in advance, Gilles Lajoie Quote Link to comment Share on other sites More sharing options...
DAW Posted June 11, 2004 Share Posted June 11, 2004 Have you looked at the '81 L28ET set-up? Quote Link to comment Share on other sites More sharing options...
Guest Gillez260ZT Posted June 12, 2004 Share Posted June 12, 2004 What kind of setup do the 81 turbos use? I'm not familiar with it. Quote Link to comment Share on other sites More sharing options...
DAW Posted June 12, 2004 Share Posted June 12, 2004 The dampner has a toothed wheel and the timing cover mounts a crank angle sensor pickup. The later L28ETs used a distributor CAS. Quote Link to comment Share on other sites More sharing options...
Guest Gillez260ZT Posted June 12, 2004 Share Posted June 12, 2004 Wow, I didn't know that. I have the factory service manual for an 83ZX and assumed all the turbos had a distributor mounted system. Do you know how many teeth are on the toothed wheel for the 81 turbo? Are you running a programmable engine management system on your car? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
DAW Posted June 16, 2004 Share Posted June 16, 2004 The '82-'83s do use a distributor-type crank angle sensor but the '81s have a crank-type sensor. I don't know how many teeth, but a lot. I'm not using this set-up, I've just seen it. I need a CAS to use on my road race PL510 and this may be what I need. DAW Quote Link to comment Share on other sites More sharing options...
