Guest 3154tm Posted May 29, 2004 Share Posted May 29, 2004 the consensus seems to be that the drive shaft pinion flanges in the r200 diff are interchangeable between the '91-'96 Z32 and the '91-'96 Q45. i need to do this swap to solve a clearance problem. anyone out there actually done this? will an earlier Z r200 pinion flange work in the Q45 diff? conversely, does anyone have a NA Z32 pinion flange i could have some mearsurements from? thanks. Quote Link to comment Share on other sites More sharing options...
