N47 or P90A for my L28et build?
Phyte
I would not use any head which had port liners in a turbo application. The port liners can loosen with the heat changes that the port will undergo between boost and non-boost. Also any restriction in exhaust port does not assist turbo motor as it can a N/A. I would stay with the P90. Also the P series heads have a larger squish area which helps reduce detonation.
The stock L28ET has to low a compression ratio IMO and I am building a flat top F54/P90 combination for my Challenge car. This set up should net me approx 8.5/1 with minor combustion chamber mods.
A compromise is to use a N42 head which has smaller comb chambers that the P90 but it doesn't have the improved squish area. I would stay with the P90 and change pistons first.
Rick
Guest bastaad525
P90 head has better shaped combustion chambers as well, a more modern 'heart' shape as opposed to the round shape of the N42/47. Supposedly the heart shaped chambers are better at getting the fuel and air mixed... better quench area or something (sorry I forgot the technical mumbo jumbo :D ) and are much more resistant to detonation... better for turbo.
