Guest hybrid383 Posted June 8, 2004 Share Posted June 8, 2004 I tried to put my 14 x 6 with 245 60 14 and they rub on my front shock. Do I need coil overs or spacers? Please advise Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted June 8, 2004 Share Posted June 8, 2004 Coilovers would be the ultimate fix. A spacer will fix it also, but will obviously push your tire out. You can make up your own coilover set-up(for a 240Z, 280 is alittle harder) from Stock Car Products, or buy the readily available kits from Ground Control, Modern Motor Sports, Fonebooth.com or a host of others. Also, It would be a great time to replace bushings, struts, etc... if you need to. Quote Link to comment Share on other sites More sharing options...
ZROSSA Posted June 8, 2004 Share Posted June 8, 2004 If they are rubing on your shock and not the spring pearch then you need a spacer. If its hitting the spring purch you need coil overs. Douglas Quote Link to comment Share on other sites More sharing options...
