Wheel rubs
Guest hybrid383
Guest hybrid383
I tried to put my 14 x 6 with 245 60 14 and they rub on my front shock. Do I need coil overs or spacers? Please advise
Guest JAMIE T
Coilovers would be the ultimate fix. A spacer will fix it also, but will obviously push your tire out. You can make up your own coilover set-up(for a 240Z, 280 is alittle harder) from Stock Car Products, or buy the readily available kits from Ground Control, Modern Motor Sports, Fonebooth.com or a host of others. Also, It would be a great time to replace bushings, struts, etc... if you need to.
