V8zx...Alive again...
Well, well, well the z is once again gettin the v8, we went to look at the fiat ans found major rust and it isn't worth the work, but i was wonderin how fast would my zx be if it had a 360hp motor???
Lets see. We'll assume your car (which is 2825lbs stock) weights in at about 2900lbs once the conversion is done. Make that 3100lbs with driver.
With 270hp the numbers turn out to: 1/4 mile: 13.13@103.81mph.
With 360hp: 1/4 mile: 11.93@114.25mph.
I believe these equations presume absolutely perfect conditions, your results will likely be a bit slower than this. (due to wheelspin, poor Z aerodynamics, etc)
I'd guestimate that you could add on about .5 seconds to get a more realistic number.
"Gimme Fuel,
Gimme Fire,
Gimme that which I desire"
-Metallica
Drax240z
1972 240z - L28TURBO transplant on the way!
http://members.xoom.com/r_lewis/datsun.html
