HELP!!!! I need to know where the tach wire is on my 74 260z
Guest scarab260z
Guest scarab260z
I just put a 350 olds in my 260 and forgot to lable my tach wire when i pulled out my 26L i could get a manual but id rather some one just tell me thanks :D
  • 1 month later...
Guest slyfontaine
If you are using the original tach in the dash then your wire is the blue wire that is going to your transistor box on the passenger footrest area. You'll need to install a 15 ohm resistor to this so the needle doesn't bounce around.[/b]
