82 zxt vacuum ?
Guest cw280z
Guest cw280z
i am trying to figure out the cleanest and simplest method of running the air reg. aux air sensor,egr, tps, it's a stock 82 turbo motor with a 60mm throttle body and 3' stainless exhaust . the prevoius owner shimmed the pop off valve and says it's @ 10 psi? i'll have to find out once i'm running.
if any one has notes from there swap on vaccums and cleaning up the
motor i would be greatful. i'm not doing ac!
