Guest 4.3L 280z Posted July 4, 2004 Share Posted July 4, 2004 I have a 75 280z and I completed the swap and finally trying to get it running. first off I don't know what happened to the neutral safety switch. I guess they were coming through the firewall and going to the tranny and must of cut them now I don't know which ones they are. Also I have my positive wire going to the seloinoid, I have to have the white wire going to the large terminal on starter Sel. but which white wire? there are many thick ones. and is the black-yellow wire only used to provide power to fuel pump during cranking? I need to get this done by the end of this week. Thanks, Nathan Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted July 4, 2004 Share Posted July 4, 2004 At this point a test light and an OHM meter/continuity checker are going to be your best friend. Do the ohm meter/continuity stuff with the battery disconnected. I believe you can bypass the neutral safety switch. I may be wrong on this tho. The Z cars have way too many wires for me, that's why I removed all of it and starting over with all new wires. Quote Link to comment Share on other sites More sharing options...
Guest 4.3L 280z Posted July 4, 2004 Share Posted July 4, 2004 already did that. I was either going to bypass it or hook it to my ratchet shifter since its already got one built on it. I was just wandering which wires they are. The chiltons or haynes manuals don't seem to be accurate maybe someone has mest with the wiring or all this beer I'm drinking while I'm messing with the car Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted July 4, 2004 Share Posted July 4, 2004 Here, try this web site out. It's helped me a great deal. Who wouldda thunk? Autozone of all places. I went ahead and did the prelim search for you. Just click on the column on the right for what you need. Oh, don't forgrt to bookmark the site. I printed mine out. http://www1.autozone.com/servlet/UiBroker?ForwardPage=az/cds/en_us/0900823d/80/1d/1e/97/0900823d801d1e97.jsp Quote Link to comment Share on other sites More sharing options...
