john kosmatka Posted July 10, 2004 Share Posted July 10, 2004 What does the carbon canister do and will I need it for my l28et? Thanks John Quote Link to comment Share on other sites More sharing options...
Guest HolyLlama Posted July 10, 2004 Share Posted July 10, 2004 It collects fuel vapors from the gas tanks and sends them into the intake manifold, so it's fairly nonessential. I pulled it off my engine and plugged the hoses and it ran fine. Quote Link to comment Share on other sites More sharing options...
john kosmatka Posted July 10, 2004 Author Share Posted July 10, 2004 Thanks, Also I'm putting my N42 intake on my turbo motor and I took every thing off of it and left a few vaccum taps on it. Will the motor run ok with no air regulator, cold start injector, etc. By the way I have stock efi. Thanks John Quote Link to comment Share on other sites More sharing options...
Guest HolyLlama Posted July 11, 2004 Share Posted July 11, 2004 If by air regulator you mean air flow meter then no, if you could find or rig an aftermarket cold air intake system that replaces the air intake up to the throttle body, then yes. The AFM is tells the ECU how much gas to send to the engine, so if the AFM isn't hooked up, the ECU doesn't know how much gas to send. From expecience, I know if the AFM is disconnected, the engine dies, I assume the ECU doesn't send any gas at all, but I don't know too much about fuel injection. I do know on an NA engine just about everything on the intake manifold (except the throttle body) can be removed and plugged with little or no consequences. The only thing I'm not sure of is if it will affect the AC, I know some lines off the intake run back to the AC, but my AC doesn't work, so I wouldn't know if the AC stopped working with certain lines disconnected. Quote Link to comment Share on other sites More sharing options...
john kosmatka Posted July 11, 2004 Author Share Posted July 11, 2004 Not talking about the AFM, but you kinda answered my question anyhow. Thanks, John Quote Link to comment Share on other sites More sharing options...
