MSD boost timing master
Guest jeremy_datsun_1976
Anyone out there using this set up.I was thinking of using it on my stock turbo set up.I am using the 6al now.I am running n47 head, f54 block ,stock turbo, 77 electronics,npr intercooler,w/bov.
Guest shuyun
i am using a 6btm on my 73 240z. I have just finished installing a 1981 28T motor setup with a draw through turbo setup. I have not had it running yet i let you know how it works out. I plan to crank it friday!!!
I'm using a MSD 6BTM in my 72 240Z with TT383 Chevy. The btm retards ignition timing which may be adjusted with a rotary dial for 1-3 degrees per psi of boost. Total retard is 20 degrees depending on the adjustment and the amount of boost generated.
I run 10 to 15 psi boost and retard 3 degrees per psi. When the engine reaches 7 psi, timing is retarded by 20 degrees. I'm losing power at launch but the topend is awesome.
If you run 10 psi on your engine and you only adjust for 1 degree of retard then your timing will retard only 10 total degrees, and etc.
I would not run my carburated blow-through turbo engine without the btm.
Hanns
This should help with my 0-60 take off.First gear goes super rich I think because the air /fuel gauge goes all the way red.I can take off in second and she pulls hard 3 and 4th also.I think since I dont have the turbo electronics the timming is adv too much when boost comes up.I think lowing the timing 10-15 degrees should help solve this problem.I have no fuel problem just timming I think.
Jeremy
