74.5 347Z Posted July 27, 2004 Share Posted July 27, 2004 I Installed a 7/8" pull type slave cylinder thru the hole in the bellhousing and installed a stock 5/8" MC. The travel of the clutch fork is just over the ".375" was written on one of the post I found from some time ago. Can someone please verify that the clutch will disengage with only 3/8" of travel? Here is a pic of my install: Quote Link to comment Share on other sites More sharing options...
Capt_Zorro Posted July 27, 2004 Share Posted July 27, 2004 Engine looks great.. One way to check the clutch engagement is to put the car in gear, depress the clutch and have a buddy try to spin the rear wheels manually. If they will turn the clutch is OK. Keep us updated on the installation. Adios Amigos, Quote Link to comment Share on other sites More sharing options...
74.5 347Z Posted July 28, 2004 Author Share Posted July 28, 2004 That would work if I had a driveshaft and axles. Sorry for the deceiving photo. Here is one of the entire car. I was hoping that someone knew for sure that that would be enough travel, or if someone knew the make and model of a car that has a bigger master cylinder. Mark Quote Link to comment Share on other sites More sharing options...
JoshB 240Z Posted July 28, 2004 Share Posted July 28, 2004 3/8" doesn't sound like enough throw to disengage the clutch. My setup, a Wilwood pulling slave and Tilton 1" master, throws about 1/2". This works well but I have been told by Wilwood that this may be too much master cylinder for the slave. The Tilton master cylinders are very easy to install into a Datsun with only one minor modification...the clevis needs to be fitted to the Datsun pedal. Installing the Tilton master seemed like a bolt in after getting the Ford engine in the car. These master cylinders are about $60 from any race shop. Quote Link to comment Share on other sites More sharing options...
Capt_Zorro Posted July 28, 2004 Share Posted July 28, 2004 Mark, Do you have a yoke that will fit on the output shaft of the trans? If you do see if it will turn with the clutch in. I originally had an Aluminum Buick V-8 in my Z with the Datsun 5sp. a conversion by D&D fab. I ended up changing it out because of the constant struggle with the hydraulic clutch. That was about 15yrs. ago so hopefully there are solutions to these problems now. Adios Amigos, Quote Link to comment Share on other sites More sharing options...
