Wiring Help
Guest shuyun
Guest shuyun
On my 1973 Datsun 240 the harnis runs across the front of the car under the radiator. It splits into two and runs to a block and the ignition. I am unable to desifer the wiring diagram what is the block and what was the other wires attached to. The factor ignition was cut and taped and I am having problems geting the car to start. What was removed?
Help.
Guest slyfontaine
Could be your voltage regulator for 1 and the other, is it on the drivers side? Could be the coil and ballast resistor you are talking about. Hope this helps a little.
