VG30E vs. VG30DE physical diff's?
1FASTKINGCAB
I was walking around the junkyard looking for a clean VG33 core motor and stumble across a Infinity QX4 with a VG30DE engine in the cargo area. after a close inspection (as close as the wasps would let me :o ) the motor mounts look 100% identical as does the tranny bolt pattern.
I know that when I ordered my flywheel clutch masters sent me one for a 90-96ZX-TT and the cranks bolt pattern was 1 bolt off but the clutch was the right diameter and the pressure plate bolted up. The QX4 had a similar looking bolt pattern.
I was thinking the reason Z31 owners might not swap in the VG30DE is because the HUGE twin cam heads would interfere with the shock towers. My truck which has 98% the same frame as the QX4/pathfinder and no shocktowers.
Thanks, Tom D
anyone have any thoughts? I might try a swap it into my other 4cyl nissan TK.
