74.5 347Z Posted August 13, 2004 Share Posted August 13, 2004 I bought a harness from E Z Wiring and now trying to decipher the Datsun wiring diagram. The ignition switch has a black w/blue stripe wire that just disappears off the wiring diagram and I can't seem to find where it goes to. It is labeled "R" on the wirng diagram, does anyone happen to know where it goes? The wiring harness has five wires that goes to the ignition switch and the switch has five wires, I am not sure where this one wire goes. At first I thought it would go to the coil but the diagram shows it to be momentary when the key is in the start position. BTW, it is a 5.0 engine and a GM colorcoded harness. Thanks, Mark Quote Link to comment Share on other sites More sharing options...
srgunz Posted August 13, 2004 Share Posted August 13, 2004 I think yours is wired the same as the 240's 5 wire switch. The wire colors may be different though on yours. In the start (momentary) position 2 wires are connected to power. One goes to the starter (blk/yel) and the other (grn/wht) goes to the tachometer first, then back out to the coil positive. Quote Link to comment Share on other sites More sharing options...
