What brackets should I keep in the engine bay
Zerrari GTO
I've got my car down to the bare shell now and have started stripping and sanding the front end. My question is-are there any brackets I should save in the engine bay? The only ones I see that I know I will use is for the windshield washer fluid bottle and throttle cable. I want to keep the engine bay as clean and simple as possible so if I don't need it I don't want it. Also, what type of body filler should I use to cover unused screw holes in the engine bay?
Thanks for any help I can get!
Guest DiZeased_240
You should weld the unused screw holes and grind them flush to the panel. Body filler will not hold and will eventually crack and fall out. Filler is not meant for filling holes.
Guest 305240
Another idea is put a screw and bolt in the holes, tighten them down, then grind the tops off of them. If you ever want to use them again, just finish taking them out from the other side.
