Guest 305240 Posted August 18, 2004 Share Posted August 18, 2004 I can't seem to get any answers on this. I've also searched archives and manuals, along with wiring diagrams. I have the complete underhood wiring setup for the 82 5.0 stang. The wire going to the ignition calls for a resistor wire. Nowhere can I find what size or length wire it takes. I know there is a difference in length. Would I do better with a regular ballast resistor? And if so, what size. Which car can I get one off of? I know you are the man when it comes to this kind of stuff. Thanks again. Quote Link to comment Share on other sites More sharing options...
Capt_Zorro Posted August 18, 2004 Share Posted August 18, 2004 305240, Don't know about "being the man", just have a lot of time on my hands to search the web and years of "wasteing my time" as my Father used to say. All you need is a ballast resistor 1.2 ohms is what the duraspark wiring diagram calls for. Jason Fletcher's webpage has a lot of good info on Ford applications. http://www.jason.fletcher.net/tech/duraspark/duraspark.htm You can get one at the auto parts or I got one with the wiring harness from an old Duraspark dist. when I picked it up in the junkyard. They are starting to get difficult to find around here. Adios Amigos, Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted August 19, 2004 Share Posted August 19, 2004 Thanks Capt! I knew you would come thru. You da man! Quote Link to comment Share on other sites More sharing options...
