Water Temp.Sending Unit
The water temp has a single (usually yellow) wire with a female connector that fits over the male brass end of the water temp sending unit.Located on the front and has a steel metric pipe fitting ( requiring about a 14 mm wrench or socket to properly remove) holding the temperature inside the thrmostat housing. Use a liberal dose of WD 40 to lossen the pipe fitting up. Also the brass sending unit may be corroded to the retaining steel pipe fitting. Last I heard these sending units were over $20.00
