Shaved Door handles
icesky
IMO, The only way to go is welding. take sheet metal, cut it, shape it, then mig weld it. Be very careful that you take your time when welding. You can easily warp the metal if you get the area to HOT because it is so thin. Grind down the welds a little, and then use filler/bondo to smooth things out. Make sure to block out the body work and try to finish your body work w/ 180grit. I would wait about a week or so after primer before painting to allow for body work shrinkage, so sand scratches and waves dont show thru the paint. Anyways -- good luck, this is the way to go if you want it to last and look good.
I chose the spal 7 on ebay, and two popper which kinda suck cus they stick out a bit. Hooked up the solonoids to the door handle and all seems good. i cant remember the name of the cold welding glue I chose but I think it was lord, and seems to be holding up to this day,(remeber to prep surface or will pop off later).[/quote
the glue is not an issue has i have a welder.
but did the popper come with the kit?
bob
