humor for the day
GabeRoc
After every Qantas Airlines flight, pilots complete a gripe sheet which conveys to the mechanics problems encountered with the aircraft during the flight that need repair or correction.
The form used is a piece of paper on which the pilot completes the top part listing the problem, which the mechanics read and then respond in writing on the lower half of the form what remedial action was taken,
so the pilot on the next flight of that plane can review the form before taking off.
Never let it be said that ground crews and engineers lack a sense of humour.
Here are some actual logged maintenance complaints and responses
P =the problem logged by the pilot,
S = the solution and action taken by engineers.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough,
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back order.
P: Autopilot in altitude hold mode produces a 200 feet per minute descent
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level
P: Friction locks cause throttle levers to stick.
S: That's what they're there for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit
S: Cat installed.
Guest BigWhyteDude
P: loud sound in console, sounds like a midget banging a hammer
S: Took hammer from the midget.
:lol: I read that one a while back but it still cracks me up, as did all of these.
Andrew
