Guest mescalinedreamz Posted September 23, 2004 Share Posted September 23, 2004 I just bought a 240z with no front turn signals hooked up. So im searching the wires up there with a test light. I turned the left turn signal switch on and tested a yellow with white tracer wire. It started the test light blinking. I then had the wife turn on the right turn signal and accidently left the test light on the yellow/white wire for a sec and it started blinking with the right on too? So i have this wire and have a haynes manual that says nothing about a yellow/white wire for turn signals. Its a 73 240z. Why is this wire blinking when both turn signals are on? Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted September 23, 2004 Share Posted September 23, 2004 Looking in my Factory Service Manual (FSM) for the 240Z, the only yellow/white wire(s) in the engine bay would be going from the oil pressure sender and the thermal coupler (?) to thier respective gauges. I have no idea why those would be flashing. Acording to the FSM, here is the wires for the turn signals. There is three wires to each side: Drivers side turn signal and parking light -Green/Blue -Green/Red -Black Passenger side turn signal and parking light -Green/Black -Green/Blue -Black Hope this helps you out. !M! Quote Link to comment Share on other sites More sharing options...
Guest mescalinedreamz Posted September 23, 2004 Share Posted September 23, 2004 my haynes manual shows me the same thing, i didnt get a chance to check all the wires, just any that were getting power when the signal was on. There are a couple more cut off in the harness that i need to take out to check. Maybe that explains why i dont have my water temp hooked up! But this system has haltech in it and i just bought the car. So im finding all the bugs. I just failed to notice the YW wire in the haynes manual until about 10 secs before you replied. I decided to give it another look. Thanks for your help!. The YW is also hooked to the tach in the diagram. The tach isnt hooked up either. He does have a 3 wire tach hooked up though, but one wire came off and he cant find it. Still more bugs! Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted September 23, 2004 Share Posted September 23, 2004 Hmm... there isn't any yellow/white wires hooked up to the tach in the FSM. !M! Quote Link to comment Share on other sites More sharing options...
Guest mescalinedreamz Posted September 23, 2004 Share Posted September 23, 2004 i meant GR from the turn signal is hooked to the tach. Quote Link to comment Share on other sites More sharing options...
