Fuel Line questions...
PhaTTy
I will be running the Aeromotive Regulator ( http://www.jdsperformance.com/index.asp?initemuid=402&fcmd=item&inmake=all ) with a high volume 700hp fuel pump and a custom O-Ring fuel rail and was wondering what type of fuel line to get. I like this: http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=2701&prmenbr=361
but was wondering if I should run the braided hose all the way back to the pump and what type of AN fittings are best for the regulator / rail / pump / etc.. (do they make quick disconnects or easy removable fittings?)
Thanks guys
For that type of power handling, you should run -8 steel braided all the way up. I wouldn't consider using the stock lines whatsoever.
-6 is rated to "499hp" from what I've read... so -8 is what I'm going with, too. (I'm going to hit 600 eventually)
