Guest TBroZ Posted January 30, 2003 Share Posted January 30, 2003 2.0 thousand dollars. Buying it without knowing what the motor was like...I figured it was still a good deal even if I had to replace the motor. Turns out the motor's running, and though it had a sticky lifter making lots of noise, after running it for a few minutes the second time, it unstuck! I still need to change the oil, and put in some Rislen...I think it could still be quieter. It's a long way from some of the gorgeous LT1 machines I've seen...but maybe someday. For now, I'm going to get a T5 ($500), an R200 ($150), probably a Quaife LSD ($1,300) and have a BeastZ for $4K. Another $3K in paint, rims, tires, and spoilers and I'll have a sweet ride for $7K. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 30, 2003 Share Posted January 30, 2003 TBro that lifter will probably loosen up. Give it a chance and it can be replaced.. Do a compression on that motor.Find out more about the engine.Every Scarab 327 Z deserves a Muncie 4 speed Quote Link to comment Share on other sites More sharing options...
Guest TBroZ Posted January 30, 2003 Share Posted January 30, 2003 Tomahawk - Why do you say "deserves" a Muncie 4 spd? I know they're strong, but I need the OD. Terry Quote Link to comment Share on other sites More sharing options...
Heavy Z Posted January 30, 2003 Share Posted January 30, 2003 If you do go the T5 route, look for '88+ camaro applications, pre-88 are weaker non-world class units. Quote Link to comment Share on other sites More sharing options...
