Guest Daddyrick Posted October 16, 2004 Share Posted October 16, 2004 I have a chance to pick up a 90's model rear suspension complete. Is it possible to use any of it in a 77 280? Quote Link to comment Share on other sites More sharing options...
olie05 Posted October 17, 2004 Share Posted October 17, 2004 It would be far from a bolt on in anyway. Below is the link to a website of these people that put a supra IRS under a '65 mustang. You will probably have to do something similar to what they did if you are planning on using the whole IRS. http://www.suprang.com/suprang3.html Quote Link to comment Share on other sites More sharing options...
maichor Posted October 17, 2004 Share Posted October 17, 2004 I used just about everything. See my writeup here: http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=37733 and pics at photos.yahoo.com/maichor75104 The Z32 subframe is about 2" wider than the S14 one I used. Most of the parts are interchangeable with the 90's Infiniti J30 and Q45. Including the short nosed R200. The twin turbo came with an R230 which has wider set bolt mounting in front and rear of the subfame. If you go this route you will have to adapt the subframe. But, since you have the whole setup, you can make it work. You will probably need some good flares. Quote Link to comment Share on other sites More sharing options...
