HELP!! 300ZX CV Shaft Conversion
Guest FLiPSyDe71
Guest FLiPSyDe71
Has anyone performed the 300ZX CV Shaft conversion? One of the directions is to reverse the bearing of the CV shaft to shorten it a quarter of an inch. I did that but when I install it, it seems as if its still a little too long....the suspension doesn't angle enough so that the strut cartridge doesn't align correctly with the top of the strut tower....the length of the axle is stopping it from angling and inch more to the correct position. I know the driver's side is shorter than the passenger side....it was clearly obvious that one was longer than the other, so I used the longer one on the passenger side which installed perfectly.
I had these two shafts rebuilt by some driveshaft guy who I'm a little sketchy about. There's two sets of bearings on each shaft...I reversed the one that's closest to the wheel as instructed....but I suspect that maybe this guy who rebuilt them put the other bearing backwards too which in turn might of made in longer??? I dunno...I'm stumped. I have no other explanation. I don't understand why this doesn't fit. I can't look at the other bearing because unlike the side I'm suppose to reverse, there is no cap that I can just pop off. I'd have to break the newly fastened clamps.
I took the cap off, and measured the length...from end of spline to end of spline and it turned out to be 19.5 inches. Can someone verify if this is the correct length for the drivers side? ANY INFO would be GREATLY appreciated. Thanks!!! -jAy
  • 3 years later...
Yes I'm also expericing simlar problems with my setup, I have an open R-200 diff. After I drove my Z and noticed that some kind of binding I figured that maybe the diff was going bad, but after I removed the CV- half shaft and looked into where the spline part of the shaft slides into the diff I could see some kind of rubbing on this metal block that is sandwiched between the two splines and between the spider gears, sorry for my lack of proper wording of parts. My guess is that maybe I have to look for a shorter shaft for the passengers side half shaft? Any help would be greatly appreciated.
