l28 engine removal
Guest 83supaZ
Guest 83supaZ
where are the best places to connect chains to remove the l28.. i have a haynes book.. says at the corners of the head but i didnt see any place to connect... it hidden under the intake or distributor?
I attached mine at the rear of the motor to the rear most exhaust bolt, and on the other side to the bolt that holds the Power steering bracket (Aust) at the front.
Mine already had a lifting mount provided that this bolt went through at the front. I had to make a simple plate up to attach for the rear.
