Help with my rebuild please
Guest gbvol54
Guest gbvol54
What should compression and leak-down tests results on a rebuilt (but yet to be started) long block look like?
I just finished assembling the long block (SBC 350) for my daugther's Trans Am (yeah, the Z has to wait again.....). I did an economy rebuild; honed cylinders, new rings, bearings, timing chain, oil pump and a mild/medium cam (couldn't resist). Got some "rebuilt" heads off e-bay which yeild 9-1 compression. I decided to check out my work prior to installing in the car. A compression check shows 130ish PSI in most cylinders with #6 at a low of 110. A leak-down test shows consistent measurements around .95 with (again) #6 at a .9 reading (leaking through the exhaust valve).
How much is too much? I'm afraid I should at least pull the head and lap the exhaust valve on #6 to get it consistent with the rest, but even then, is 130 PSI reasonable for a unfired rebuild?
