510six Posted November 15, 2004 Share Posted November 15, 2004 I did a leakdown and compression test on my 3 liter today and found #2-3 cyl were at 15% leakdown while the rest were at 4-5%. The compression test showed 150psi on 1-4-5-6 and 135 on 2-3 so it`s time for the motor to come apart.I didn`t hear any much air past the valves so I might have some broken rings(I`m guessing). I`ll know for sure when the motor is torn down, I`m just amazed it has lasted so well from all the abuse I have thrown at it.A friend with a VW running similar times has gone through 3 motors and I can`t imagine any Honda holding up to as many repeated drag launches as this motor has. Quote Link to comment Share on other sites More sharing options...
technicalninja Posted November 15, 2004 Share Posted November 15, 2004 I would guess either Broken 2nd rings or lands Or slight headgasket blow between 2 and 3. I would look closely at HG before taking bottom end apart. BTW- the 4-5% leakdown on your good cylinders is excellent for a motor that has been "applied properly". Quote Link to comment Share on other sites More sharing options...
510six Posted November 15, 2004 Author Share Posted November 15, 2004 The motor had over 200 drag passes on N20 so I would imagine that the rod bearings would need to replaced.The Pistons are VG30dett types from JE with L series valve relives and Cunningham rods I don`t hear any indication of broken pistons so hopefully the rings are bad.Worst case senario is a new set of pistons and .5 millimeter overbore.I will have a valve job done as well since the motor is apart.The headgasket is a NISMO multi layer SS unit but with nitrous I could see the gasket getting torched between cyls.As the cyls are "O" ringed with SS wire it would have to be one serious blowout.I am thinking a piston would give it up first.But, one never knows. Quote Link to comment Share on other sites More sharing options...
