recommendations
Adimir
ok i have been reading up on t3/04e and 04b turbos...
i understand that E is more efficient than B, but B spools up quicker...
am i getting this so far? or does this have also to do with AR numbers?
so what would you guys recommend for 300 hp range (+- 50hp).
ive looked at this on ebay
.96 A/R WITH A P TRIM WHEEL. THE BEARING HOUSING IS OIL COOLED ONLY. THE COMPRESSOR WHEEL HAS A 51.6mm INDUCER AND A 70mm BACKWALL. THE COMPRESSOR INLET IS 3", AND THE OUTLET IS 2". PAYMENT DUE TEN DAYS FROM END OF AUCTION.
would this be suitable? if not then what would be just right?
thanks alot![/img]
