manual trans
Guest rick458
I know that Summit carries the Richmond Over Drive 5 and 6 speeds
RMG-7021710A
Richmond Street Five Speed Transmissions - RMG-7021710A
$1,889.00 2
Should Ship By: Today
Add To Wish List
2. The part has an additional shipping charge.
Application Guide
Tip
page marker
Overview spacer
A transmission built with performance in mind.
Transmission GM 5 speed 1 1/8-26 spline
These Richmond street five speed transmissions deliver the ultimate blend of performance and economy. Utilization of four extra low gear ratios provide dramatic improvements in acceleration, while a 1:1 fifth gear allows maintenance of original fuel economy.
Vendor Richmond Gear
Product Line Richmond Street Five Speed Transmissions
Number of Gears Six
Input Shaft Diameter (in) 1 1/8
Input Spline Quantity 26
Output Shaft Spline Quantity 32
Output Shaft Spline Diameter (in) 1 3/8
Tailshaft Length (in) 7.57
Bellhousing Included No
Yoke Style Slip-on
Yoke Included No
Shifter Included No
Shifter Style Required Long
First Gear Ratio 3.28:1
Second Gear Ratio 2.13:1
Third Gear Ratio 1.57:1
Fourth Gear Ratio 1.24:1
Fifth Gear Ratio 1.00:1
Sixth Gear Ratio (Not Specified)
Seventh Gear Ratio (Not Specified)
Case Material Aluminum
Quantity Sold individually.
Notes (Not Specified)
Warranty spacer
Instructions spacer
Fitment spacer
Suggested Parts spacer
Larger Image spacer
spacertop of page
RMG-7021626AA
Richmond Six Speed ROD Transmissions - RMG-7021626AA
Image is a representation of this part. Actual part may vary.
$2,899.95 2
Add To Wish List
Application Guide
Tip
page marker
Overview spacer
A transmission for the driving enthusiast.
Transmission 6 speed
These Richmond Six Speed overdrive transmissions were designed with the driving enthusiast in mind. The six speed transmissions are made in the U.S.A. by American Craftsmen using the latest CNC machining and in house heat treat. Based on their bullet proof five speed design, the Richmond ROD has another gear-to-grab overdrive! Aided in design with NASCAR proven technology, the Richmond ROD features smooth, positive and fast shifting. Available in multiple gear ratios, the RODs deliver strong, light weight performance. Engineered with a pro-quality approach, the Richmond ROD delivers the strength and performance you expect!
Product Line Richmond Six Speed ROD Transmissions
Number of Gears Six
Yoke Style Slip-on
Yoke Included No
Shifter Included No
Sixth Gear Ratio 0.76:1
Warranty spacer
Instructions spacer
Application spacer
Fitment spacer
Larger Image spacer
spacer
as you can see those are pretty pricey 2200-2900 bucks
  Mike kZ said:
What's wrong with a T56? They come stock behind LT1s
Ditto. I have a T5 and I'd much rather have a T56. I bought the T5 because I already had a carbed motor and the T5 was CHEAP and nearly 'new'. If I was doing an LT1 swap, I would most certainly install the T56 that was mated to the engine. It's a tough combo that just plain works. Also, the T56 is stronger and can take some real abuse.
Davy
