EZ-E Posted December 4, 2004 Share Posted December 4, 2004 Of some sort on a 1982 280 ZX Turbo, its under the glove box area, closest to the radio. What is there that could be leaking, Ive found a few lines but no bubbles from spraying a bubbly mix of detergent and nothing visual. Any ideas? Quote Link to comment Share on other sites More sharing options...
Guest 240zJake Posted December 4, 2004 Share Posted December 4, 2004 AC vent operators? are they vaccum powered? Quote Link to comment Share on other sites More sharing options...
technicalninja Posted December 4, 2004 Share Posted December 4, 2004 Lots of vacuum controls in dash, Especially with the automatic temp control system found on GLLs and turbos. Removal of glove box may allow diagnosis. Possible culprits- vac feed line has connector in it right in that area, the vac control head is bad about leaking (just behind control panel), and multiple blend door actuators that are now 20+ years old. Does your A/C heater system work properly? IE vent selection works, you can hear the recirc door close when recirc is chosen. If 1 item doesn't work then look at it for vac leak. If nothing works properly look for a break in vac source (feed) line from engine or problems with the control head. Rick Quote Link to comment Share on other sites More sharing options...
