Guest zline Posted December 21, 2004 Share Posted December 21, 2004 So I have looked to the 1UZ-FE for my engine need mated to a W58 mission, to simplify things I want to use a megasquirt computer...but it seems as though its just complicating everything. I need to ditch the distributors on the front of the motor for some extra room off the front of the engine, The 1UZ ignition is operated by a crank trigger, and then has 2 (4 cyl) distributors, 1 mounted on each bank of one of the overhead camshafts. Also attached in each of these are a cam shaft position sensor. Would it be possible to use EDIS8 on a setup like this and do away with the dizzy all together and just replace the crank trigger and use the megasquirt to control the ignition? Quote Link to comment Share on other sites More sharing options...
