OEM Spring Rates
Guest Petez240
Guest Petez240
Seems to be a lot of questions concerning coilovers, spring rates and so on. I'm buildning my own adjustable coilover setup and it's always very interesting reading here at Hybrid Z!
Just for fun, does anyone know the OEM spring rates for the z-series? I got a '73 240Z and I've measured one of my shortned OEM springs to approx 28 N/mm or 160 lbs/inch.
Hej Peter,
According to Bob Waars book â€How to hotrod and race your Datsun†page 149 the 240Z European spring rates (Stage 1) are 100 lbs front and 112 lbs rear. Those spring rates are said to be an approximate 21 % increase in front and 11% increase in the rear over the U.S. spring rates.
The book further states that the 240Z European spring rates (Stage 2) are 122 lbs front and 140 lbs rear.
This has been discussed before; a search on “spring rates†brought up 168 hits…. Here are some you might want to take a look at:
http://forums.hybridz.org/showthread.php?t=97786&highlight=spring+rate
http://forums.hybridz.org/showthread.php?t=94060&highlight=spring+rate
http://forums.hybridz.org/showthread.php?t=90109&highlight=spring+rate
http://forums.hybridz.org/showthread.php?t=87210&highlight=spring+rate
Best regards
ThomaZ
Guest Phil1934
I cut four coils in front so guess I'm about 167 #/" there. The rear feels very soft so I want to go to 225#/". Does anyone sell just the spring in stock diameter if I don't want to change everything? Ride height in the rear is fine, I could live with 1" lower but no more.
Guest Petez240
Okay, thanks guys! :D
It seemed liked my 160 lbs was a bit to heigh, and ThomaZ proved that.
There are several possible reasons:
- the spring was measured still mounted on the car
- no concern has been taken on the support from the other wheels
- no concern has been taken on the support from the Tokico strut
this will probably lover the rate with 0.7-0.8 and get me closer to the figures stated in the â€How to hotrod and race your Datsunâ€
