Question about wiring.
Guest obediencedenied
Ive never posted on here cuz ive never needed to... yall cover most every thing and thank you for your information avalable... yall need to make a book... money for the cause... but me and my friend did a sbc stroker in his 75 280.. and we used the stock wiring with directions from JTR... but i dont want to do that.. i want mine clean... and i started tracing the wiring harness... my god that is alot of wires.. and i know it wont work when i am done.. but all i am doin is the basic with lamps, turns, brake lights.. no creature comforts.. and a stereo and nitrous system... but i cannot seem to find what some posts are talkin about... That is if yall do have the wiring colors everything.... and.. i've never used a Painless.. but do you get rid of ALL old wires?
Thank you for your help.
Red
Guest 77vegasz
If you have the time, gut all the old wiring, and use a Painless harness. They are available to fit most any combination of devices that you may want. They are color coded, and easy to use. This will require rewiring all the gauges as well, unless you plan to swap to Autometer or some other MFg. in which case you would be doing that anyway.
If you follow the JTR wiring system, it works out just fine, and you do not have to go through all the hassel of rewiring. I followed the JTR manual, and had only one or two issues with the oil pressure gauge and Tach, but I ended up using new Autometer mechanical guages and doing away with all the stock Z gauges. The most importand wires to get right are the Alternator wirs, starter wire, and wiring to your fuel pump. That will get you running. At that point, the lights and all stock wiring will work fine, then sort out the guages.
Jon
Thank you.
I figured out that i will gut the hole thing.. all those wires are nuts... there are less on my friends 99 GTP at the circut board then on the Z man... but i will use the 18 circut system... but it will be a while till i can get around to buying and installing it.. cannot get full time where i work and a measly 7.50/h aint bring it to life too fast.
Thanks for the help.. this site is great.
Guest 305240
I ended up gutting mine because it was almost gutted anyway. I started with a stripped out, cut up parts car. It's looking pretty good now. With the help of a few more parts cars and ebay I've almost got everything I need. I've wired cars before, and the simplest way for me was do it system by system. Get a bunch or relays and don't be afraid to use them. I upgraded to the Honda wiper system, toyota 4x4 front brakes, ZX rear disc and master cyl.I'm sort of in the same boat as you are. I'm retired and all I get is a $500.00 a month allowance...lol...So it is taking me some time also. I also used an 1 wire GM alt to make things simple. Good luck, and keep us posted.
Yea.. ima gut it.. maybe tonight... now that i know i can.. ima have a great time gettin rid of it all... darn wires.
Yea i got a 383 stroker comin up for it.. jus for the SCAT 9000 series crank and SCAT 6 inch h beam rods right now.. along with the block finished.. may need to be clearenced tho.. but i only been goin on it for like 2 months with my lil pull. That incluedes gettin the car.. another car.. cuz i hit problems i probably shouldnt talk about in puplic... and yea.. fun times.
Guest 305240
This is what I'm putting in my Z for turn signals. (see web site below) I don't know what shape your turn signal/wiper/dimmer switch is like, but I'm not going to use the piece of junk that I have. I kind of like the rocker switch idea with the LED lights. I hace enough room to mount this little baby almost anywhere I want it. Check out the site and it may give you a few ideas. If I can be of any help, just give a hollar.
http://www.watsons-streetworks.com/switches.html
Yea i dunno... my turn switch as far as i know is perfect but i like the idea more about mounting the swiches rather then using the stock things.. but i will want one for things like killswitch(two... one being hidden) and fuel pump... ya know... i dont like some things jus wired to a hot when the car is turned on... can lead to bad things happening...
