kalium99 Posted January 24, 2005 Share Posted January 24, 2005 Just wondering if anyone has ever put an aftermarket ECU on a not too modified L28 and what the results were ? Although Im sure it may not be the best bang for your buck option, at least its something that can be picked up and moved onto another engine (non L series) when the time comes for an upgrade Quote Link to comment Share on other sites More sharing options...
GrayZee Posted January 24, 2005 Share Posted January 24, 2005 I have a re-tuned z31 ecu and the key is in the timing advance curve. There is quite a noticable difference in power. As far as actual HP numbers, I have no idea but I'm sure that any aftermarket ecu could deliver similar postive results over the stock ecu. Quote Link to comment Share on other sites More sharing options...
Kennysgreen280zt Posted January 25, 2005 Share Posted January 25, 2005 I was running my SDS system on my car last summer without the turbo, IE mostly stock. Compression is around 8.8:1. Header and exhaust, and a short intake with a cone filter got me into the 14's in the quarter. 14.8 @ 91mph incase anyone cares. If you are thinking megasquirt, or another cheaper type system, I say go for it! Quote Link to comment Share on other sites More sharing options...
Guest Magic Posted January 25, 2005 Share Posted January 25, 2005 A few years ago I put an Autronic ( Fuel and Spark)on my l28 280zx. I put on a larger 57mm throttle, K&N filter. Kept Mostly stock (igniter on the ignition) From memory on the Dyno before and after percentage wise there was a reasonable increase in RWHP 28% ???? (Will check) But the best was the improvement in Torque 35%???? It was pretty much across the rpm range. Will see If I can dig it out of my archives at home - I did this mod first for a few years and have only just added the turbo. Quote Link to comment Share on other sites More sharing options...
kalium99 Posted January 25, 2005 Author Share Posted January 25, 2005 Some of those results sound impressive. I guess that the std ECU is tuned for economy predominantly, and they are only 8 bit at that. So it would make sense that an aftermarket option provide some benefit in terms of power. EDIT: And yes I was thinking of Megasquirt or similar option Quote Link to comment Share on other sites More sharing options...
Guest zigzac Posted January 25, 2005 Share Posted January 25, 2005 I put Megasquirt on my stock L28. I had all sorts of drivability issues with the car prior to the install. After installing MS and about 5 min of adjusting values it ran better then it ever had for me. And after tuning it I was very happy. I also was getting around 28mpg cruising with MS where as stock I was running 18-20 mpg. The best part was that the car idled and ran so smooth I couldn't believe it was the same car. It also felt like it had more power and pep. I will say that my car's wiring and electronics were in very rough shape and that had a lot to do with my MS install. I also went with the GM HEI for ignition at the same time. I recomend MS as one of the best performance mods I have done to any car. I ran it for ~5Kmiles on MS before I tore the car apart for major modifications. Quote Link to comment Share on other sites More sharing options...
Guest jmjc Posted February 17, 2005 Share Posted February 17, 2005 Hi I am also thinking about the megasquirt system. The 1983 280ZXT is stock except for a complete 3" mandrel bent system & a low restriction intake. The exhaust made a huge difference in how the care comes on the turbo; however, now I am looking for more hp. I have a large NPR intercooler, weber tb & a non egr manifold next on the install list. What would realistic hp numbers be @ 15lbs on the stock turbo with the aforementioned items? I am also beginning research on a cam, any recommendations? Thanks John Quote Link to comment Share on other sites More sharing options...
