pjo046 Posted February 1, 2005 Share Posted February 1, 2005 Well, now I have finally received the 1981 Turbo ZX engine I bought from usa. I have taken off the manifolds, distributor, crank sensor etc from the block. Now I am going to put it on a engine stand. How can I check compression etc when it stands like this, not connected to power or anything...? Also, other things I should check now to be sure the block, head, headgasket and internals are ok and that I won't need to take the engine completely apart? Thourough explanations are welcome, I'm not so good when it comes to the engine block, all I know is turbos, chassis etc... Quote Link to comment Share on other sites More sharing options...
ihatejoefitz Posted February 2, 2005 Share Posted February 2, 2005 search for leak down test, if you dont find it here try google Quote Link to comment Share on other sites More sharing options...
