coolant flow direction?
GrayZee
Can someone tell me which way the water pump pushes the coolant? I know the thermostat is located in the engine where the LOWER rad hose connects, does this mean the coolant flows in a reverse pattern? I'm guessing that the hot water is pushed out the bottom hose and up the rad... pushing cooled water into the intake manifold. Is this correct? Or does it still flow in a traditional way?
